Hello, I have just updated to the latest 2.05 code and been through all of the reinitialisation steps, but I'm struggling to get the motors working right.
On the first 2 attempts at calibrating the ESCs, the AC2 Setup screen that shows the motor outputs as green bars showed them all running at very diifferent speeds.
On the second 2 attempts, when armed, the motors all immediately ran at 50% power constantly and ignored the throttle input altogether. I can see the throttle channel responding correctly with its green bar.
I have been following the automated ESC calibration instructions at
http://code.google.com/p/arducopter/wiki/AC2_ESC
At the point where the battery is reconnected and the ABC lights flash in sequence there is a repeated sequence of tones and musical notes from the quad. What do these tones mean and does it matter at what point here I move the throttle from full to zero?
Please can someone advise what I'm doing wrong?
One final question, in the CLI setup mode, what does the MOTORS command do - I can't seem to find any instructions for it?
Rob
In the auto calibration is says.
Does that mean when the ABC lights flash in sequence to drop the throttle?
This is almost immediately right?
Because after they flash in sequence the motors start singing some tunes and it makes me wonder if I should let them stop.
