Pseudorange from Ardupilot and uBlox LEA6
Hello,
I recently started working with an Ardupilot. I have connected a uBlox LEA6 receiver to it. I am currently trying to get pseudorange data from the LEA6 and it seems like I have to get the RXM-RAW packet from the receiver. I was wondering if anyone had done this before or would have any sample code ardupilot code?
I have looked through the RTK library and the GPS_Auto but I haven't been very successful in printing out pseudorange data. I believe you need the structure from the RTK library to place into the example GPS_Auto code. However I am unsure where exactly the Ardupilot is choosing and filtering packets from so I am unsure of how to retrieve packet data.
  • There are other UBLOX GPS options that put out raw as well:
    - Neo 7P (easier to find these days than the Neo6P
    - M8T
    To verify, I have successfully used both NEO 6P and 7P with RTKLIB
    • Hey B_Duffy,
      do you have a setting file to upload to use the M8T with the pixhawk?
      Having problems getting it working.
      Thanks Michael
    Derek,
    Only the 6T and 6P  modules produce the RAW data packets.
    Check my blog post here for some work I did with raw carrier phase data from a 6T -
    http://www.diydrones.com/profiles/blogs/proof-of-concept-test-extre...
    Doug
