PX4 Star Wars Startup Tone
tldr; We made Star Wars the default theme for our px4 startup
Hi, I’m part of a lab that uses pixhawks in our uav setup. While the default “alarm tones” the buzzer makes for various situations (e.g. startup, arming, battery warning ...) are good, my labmates thought it would be a cool idea to set custom ones to other tunes that our nerdier sides would appreciate. Enter Star Wars-playing pixhawk UAV. It turns out that the process is fairly straightforward, and doesn’t take too long.
There’s a reasonable guide that we used for reference. The process works great! The only file that has to be changed in the px4 firmware setup is tone_alarm.cpp (Firmware/src/drivers/stm32/tone_alarm/tone_alarm.cpp). To change the startup alarm, we modified the ANSI music styled string for the default TONE_STARTUP_TUNE on line 328 to:
328    _default_tunes[TONE_STARTUP_TUNE] = "T200L4O4FO4FO4FP16MNL2O4B-.O5F.L8O5E-O5DO5CL2O5B-.L4O5F.L8O5E-O5DO5CL2O5B-.L4O5F.L8O5E-O5DO5E-L1O5C";
The new string is set to the opening theme for Star Wars. Check it out for yourself by going into the px4 software and modifying that line to this one.
We used musicnotes’ Star Wars main title sheet music for reference. The translation is pretty close (not exact with the triplets or the tempo). The result sounds pretty much exactly like a direct transcription of the melody notes. For the musically inclined, we start at measure 3 and end at measure 7, and also use dotted notes when needed instead of changing the tempo explicitly (there may be a cap on the amount of notes that can be processed based on the length of the string, we didn’t test that much and the issue only appeared on dosbox).
We also have some other attached alarm tunes that you can check out at the bottom of this post.
If you want to make your own songs, see Ansi Music Guide. It will tell you all you need to know, and the rest is up to your proficiency in music.
If you want to check your work, and since flashing the pixhawk every time is a hassle, then we’ve included what we used to do the same, as recommended by pixhawk’s documentation (https://pixhawk.org/dev/tone_alarm) which was to download a dosbox emulator and the Melody Maker Ansi Music Editor.
  1. Download and setup the dosbox emulator (sudo apt-get install dosbox for Ubuntu, then enter ‘dosbox’ to command line)
  2. Outside the emulator make a directory (i.e. dosprogs) and unzip Melody Maker to it (if you want, also see page 14 of MELODY.DOC)
  3. Mount the dosprogs folder (i.e. in dosbox, mount c ~/dosprogs) and cd to it (i.e. enter C:)
  4. If MMV31 is in dosprogs (can use 'DIR' in the emulator to show the directory and check), then type in ‘MMV31’ and extract
  5. We opened up a file in dosprogs outside the emulator called “STARWARS” with a basic text editor and just wrote the characters to it (didn’t use melody’s interface).
  6. We played the “music” using the command 'MMUTIL /P STARWARS' through command line ANSI music player
  7. Once satisfied, we moved the string into tone_alarm.cpp, flashed, and on startup it worked like a charm
Probably took an hour to get everything going and write some of the tunes. Would like to see what other songs people would put on their drones (we're planning to put ride of the valkyries somewhere :)
Links:
tone_alarm.cpp
Tone Alarm Guide
Ansi Music Guide
dosbox
Command Line ANSI Music Player for dosbox
Star Wars Sheet Music
exampleAlarms.txt
  • Never mind. I managed to solve myself.
    I finally can build the code and update the sound.
    Thanks!
    Kyuhyong You said:
    It is very nice and useful tutorial. Thank you for sharing.
    Could you explain how I can build the modules in /src directory?
    I tried make px4-v2-quad and upload but the tone does not change.
  • It is very nice and useful tutorial. Thank you for sharing.
  • This is great work, thanks for sharing!
DIY Robocars via Twitter
RT @a1k0n: Starting on a rough guess of the track centerline as an SVG. Then I use svgpathtools to generate equally-spaced points w/ direct…
17 minutes ago
RT @a1k0n: This rules. My existing code isn't going to work *at all* -- the track planner and precomputed map are out. However, it forces m…
17 minutes ago
RT @chr1sa: Our new @DIYRobocars track at @circuitlaunch is fiendishly hard & crashtastic fun. Combines hairpin curves with an intersection…
2 hours ago
The May @donkey_car newsletter is out, with news about release 4.2, next events and more https://donkeycar.substack.com/p/may-newsletter
18 hours ago
yesterday
yesterday
RT @breadcentric: Bingo card for AWS DeepRacer Finale, starting in 10 minutes on https://www.twitch.tv/aws ! #AWSDeepRacer #DeepRacer #Machin…
yesterday
RT @NVIDIAEmbedded: It's #NanoFriday - the RB-0 uses the same suspension concept as #NASA's newer differential-bar rovers. This educational…
yesterday
RT @chr1sa: On May 22, we're returning to in-person AI @DIYRobocar racing at @circuitlaunch. The Amazon @awscloud DeepRacer team will be pr…
Wednesday
RT @breadcentric: On my CV: Hobbies: Training bananas to race on tracks #AWSDeepRacer #DeepRacer https://t.co/MKe14hNyux
Wednesday
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
Monday
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
Monday
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
