Quad doesn’t take of
It’s the first quad I built using APM 2.6. I completed all the setup procedure and when I tried to do the test flight and raised the throttle the motor started to work but very slowly (like 10% from the max power).
Any idea what can cause it?
  • Did you calibrate esc.s
    • Yes I did, I calibrated the: radio and ESC (they worked well when calibrated the compassmot)
  • Did you calibrate radio in mission planner
