Quad spins continuously 180 degrees non stop.
Hey everyone,
   Hoping one of you can help me sort this out.  Fully aware that this is probably some where already on this board however I've had no luck finding a solution.  I'm running an arducopter 2.5 on a DJI Flamewheel 450 with DJI 30 amp ESCs.  I calibrate everything and set up everything right from my understanding, however the second I lift off I spin 180 non stop.  I cant counter it and it alters every time I lift off.  I've read it might have to do with my magnetometer or GPS, that or hardware.  As far as I can tell everything is in tight and straight. Anyone have any ideas how I can resolve this? It lifts of and stabilizes just fine however the spinning is endless and throws everything stabilize wise off in a heart beat.
Thanks a lot for your help!
- DR
DJI FLAME 450
Arducopter 2.5
DX7s spectrum
  • Dennis,
    Did you check all the obvious stuff like motors oriented and wired correctly?  Prop on the correct way and in the right orientation?
