  • Thomas, did you ever get this worked out? I am having the exact same problem and I'm not sure how to fix it. Did the circle trick noted above actually work for you?
  • Hi,
    I have placed the APM in the middle of the copter and the CG is there as well,
    but i have the Problem that while taking off, the back lifts up first ! it flies, but i have to pull the elevation Stick all the time...
    it was leveled via mission planner and looks OK in the HUD. any idea ?
    Thomas
    3692685746?profile=original
  • T3
    I would think the best place would be as close to center of gravity. It doesn't have to be perfect.
