Quadcopter weight problem, low flight times
My quadcopter is V type frame.
Motors Emax 2213 / 935KV / 1045 props
Slightly soft props, not much like phantom but they are not rigid
4000 Mah 3s Lipo
APM 2.6
total weight of quad copter = 1600 grams
giving only 9 ~ 10 mins in a no wind condition and mostly loiter / hover
How can i increase my flight time (i cannot reduce the weight more)  ??
suggest me motor / prop upgrades .
    Move to a 4s battery, get lower Kv motors, increase prop size, optimize lift target for 1.15x weight at the most efficient arc for your motor/prop combo.
    Use: http://www.ecalc.ch/xcoptercalc.php?ecalc&lang=en
    • Dear Michael
      Thank you for replying, can you please explain this in little detail
  • Obviously it will need to be retuned, and be no where near as acrobatic, but it depends on what you are after....
  • Depends on the largest size of props your frame will handle, if you can get 15" props on, then swap your motors to 350-500 kv pancake motors, and double your batteries up, you will get at least 20mins....
    • Thank you Dave for the reply.
      Can you please guide can i continue my 3s battery setup and ESC if i change to 500kv pancake motors and 15" props ?
