Hi
I am building quadcopter which is ready to fly but when i try to lift it it always flip backwards everything is according to instruction. Please suggest any change is parameter or other setting so that it will lift off the ground.
thanks
Hi
thanks
Yes motors are rotating in correct direction
I had the same problem. I am a noob. I had the transmitter set up in heli mode not airplane mode. That fixed mine.
If you get the pitch working correctly and it still flips:
1. Balance is very important. When you apply throttle to go straight up and the quad is mis-balanced one side will lift before the other. The APM doesn't know that it would have to apply more thrust to the heavy side. So check the balance.
2. IF this is your first quad, often quads will tilt one way or the other in the first few inches of flight. You have to be a little bold and apply enough thrust to get it off the ground far enough so that the flight controller can start to compensate.
I used APM before and it works perfectly. I think Balance might be problem as I helped another friend with APM board and his quad was flying perfectly with same settings. I will again calibrate all hardware
In the radio calibrate screen, unlike every other control, the pitch must go down on the screen when your stick goes FORWARD on your radio transmitter.
everything is correct
when i calibrate radio it shows pitch in right direction but when I try to arm quad and fly pitch is reversed. even after reversing pitch it is flipping backwards.
