Today, my quadrotor was crashed.
During the flight, all propellers were stopped suddenly, it goes to ground immediately.
I'm guessing few reasons, but I'm not confident.
The copter configuration was
1. 'X' configuration
2. 25C, 2200mAh 3s battery.
3. Four ESC has BEC functionality, but I only use one ESC's BEC. So 5v was from ESC.
And battery was 12v when I checked on ground after crash.
So my guessing is that ESC suddenly draws large current, so voltage is dropped, then Ardupilot board were rebooted. This is my thought.
So, if anyone have some guessing, comment please. It'd be really helpful to develop my copter.
Sounds like a brown out. Just Curious, but does the Arducopter power distribution board utilize all of the BECs' from the ESCs', or does it just use one? I have been making my own PDB for my multirotors with a customized PCB board. I have been plugging my servo connectors from the ESCs' directly to the APM. Since using this method I haven't had any brownouts like I was having in the beginning. My APM gets anywhere from 8-12 amps if it needs it.
I just had the same thing happen on mine too, still unsure of reason. Broke three legs (custom units), probably from around 100ft.
modified Quad kit, with 5000mAh battery, 10x45 props, 2.0.38 firmware,
UAVCrash.mpg
Jason, this gives me an idea. On the AVR chips it is possible to detect the cause of a reboot condition.
Would it be possible to implement a fast reboot, checking for the brownout detector reboot flag ?
have you check your remote?
in my JR when fail safe active, same time trotle is loss.
so, now i set my all chanel to hold mode in failsafe setting.
hope can help your problem
Same thing happened to me, twice. The reason was aggressive flying, pulling stick to zero throttle and full left yaw, causing disarming of the controller in mid air. Very frustrating watching the thing fall from the sky, trying to arm it before it hits the ground.. :-)
Ok it is impossible that the battery goes under 5v since good cells must remain at least 3.1 volts, so 3x 3.1V will be 9.3 V aprox. To eliminate that posibility check your cells Voltage.
Check the ESC with the BEC u where using, check if it is conducting to the APM.
IMO, it could be the BEC
For a future, dont use the BEC for the ESC, try to buy one and have it isolated from the ESC's .
A log and code version would help, thanks
Some ESC's have an auto-shutdown feature if the battery voltage gets too low... could be one cause?
