I want to buy a battery pack for my Turnigy 9X 2.4 GHz 8Ch Receiver and I was told I need it to be between 4.5V and 6.5V. Is there any specs on the amps? The thing is that I found a ton of battery packs at 5 or 6V, but all with different amps... Which one should I use? Can someone point me towards a the "ideal battery pack" I could use?
Just so you know, I looked at that video and that's where I found most of my info about what I needed and how to setup the whole thing :
https://www.youtube.com/watch?v=z_-ruNd1FcU&fb_source=message
Thank you!
sorry did not see this question earlier...
All the info you need is there:
http://www.rcmodelreviews.com/tendollarbattery.shtml
Dany
www.canadadrones.com
Hi Antoine,
Looks like nobody has answered this, so I'll have a go.
Normally the Receiver gets its power from the main battery either via the control lead from the ESC or via a separate 5V BEC. Perhaps you could explain more about your setup to understand why you need a separate battery.
The receiver itself only draws 20mA. However, it may in turn be providing power to servos which can be much thirstier.
If you want a battery just for binding, 4 x AA-size Duracells would do the job.
Dave.
