Questions about telemetry through audio channel
Hello,
I'm a FPV newbie and I started building a simplitic telemetry using the unsed audio channel in my FPV setup:
1. On the plane there's an arduino with arduIMU which encodes the data in FSK.
2. On the ground I'm using a laptop with screen grabber. The audio channel goes to my sound card where it can be processed.
While it's easy to encode a FSK signal, the decoding is not so obvious. Ideally, I'd like to use a 3rd party software which reads the sound card input and e.g. sends the decoded data through a network connection. Do you know any software that does that?
Alternatively, I could use some C/C++ decoding library. I found some code for decoding bell-202 in an opensource router but it's hard to extract for mine own use without deep understanding how it works). And if everything else fails: do you know a _good_ source where I could learn about decoding FSK in practice, without using additional hardware?
I'll be really thankful for any help. I did my homework and spend a good amount of time googling but couldn't find anything that would be useful for me.
cheers!
Jan
  • It might be simpler to find a small microprocessor based solution and let that do the decoding instead of looking for something software based.
  • lol, I see no one has replied to you. I'm working on the same thing so hopefully I'll have some information in the next week.
