Has anyone tested this version of Pixhawk ?
http://radiolink.com.cn/doce/product-detail-116.html
Yes, sometimes worked, sometimes din´t it´s very bad when you are in field and waste your time trying to calibrate the compass, and also sometimes didn't fix GPS, also the pixhawk itself sometimes present errors and power issues, today only use Holybro without any problem.
Mike Foshee said:
What was the problem with the one GPS antenna? I'm having trouble getting the compass to calibrate and I'm wondering if thats my problem
Yes, it support 2 M flash
One more question from my side. I did review hi-level description only and there is a note that board supports 2MB flash.
Do you know is this true or it`s suport only 1M|B as well as 3DR?
Different conectors as in 3DR and SPKT/DSM didn't fix.
mocart said:
Finally I could test Radiolink pilot in Tuffwing frame (excelent frame by the way), about the pilot I found 2 errors:
1. SPKT/DSM port is not the standard for Spektrum receiver, so you need to cut the plug to install it
2. I order 2 GPS antennas, 1 of them was damage
Hi all...
Recently, five days ago, I have received the "Radiolink Pix" set that I ordered in July... a little bit late to do a quick review because it is the second set that Radiolink sent me... the first set never arrived and I think it was lost by the post service. Now I am out of my vacation time and I have little time to do it. I hope to have enought time to do it as soon as posible.
Thanks.
hello, I`m newbie on this forum and my current configuration base on naza solution.
I want to replace my naza by any open hardware based solution and now I looking for the best quality 2 price replacement. there is not so many posts and comments related this radiolink board and if you can please share your opinion about it. Are connectors same as in 3DR or different , how about overall quality ?
Hey There, I have one of these radiolink pixhawks and am having a small problem with it. I can not power it using battery/servo rail. It powers up fine via USB but does not boot when connected to battery. Wondering if it's a bad board or if I am doing something wrong.
I have ordered one set from Radiolink... Pixhawk and M8N GPS...
I hope had enought time to do a complete review of that set as soon as posible...
I will publish my impressions...
