Razor 9DOF IMU AHRS , used software
I am trying to built synthetic vision system for small airplane using Sparkfun component connected to my laptop
I used Razor 9DOF IMU AHRS board connected to FTI then to my laptop,
My question is how to fined a software which can give output from Razor 9DOF IMU AHRS as a picture, I mean same as the real instrument reading picture for altitude
thanks
  • i Just got my component
    1- 9 Degrees of Freedom - Razor IMU - AHRS Compatible
    2- FTDI Basic Breakout - 3.3V
    3- Single Row Break Away Pin Header – Straight
    4- Polymer Lithium Ion Batteries - 860mAh 3.7V With JST Connector
    5- LiPoly Charger - Single Cell 3.7-7V Input
    i will start to connect them all together with my laptop.>>>
    also i am still searching for write software to give me real output picture.
  • You might want to try Sourceforge - search for 'EFIS'.
    There is a project there written in C or C++ (I cannot remember) that would be a very good basis for such a display.
    Doug
  • Hi,
    I am doing the same. Currently I'm working on the data bus and then I will do the graphics. There are a few projects on google code that do something similar as well as Paparazzi.
    Have you got as far as parsing the data stream and seeing the output in a console. ?
    Regards
    Diarmuid
