RC Calibration issues
Ealier I was able to see the green lines on the Transmitter calibration tab moving.  After fidling wih the settings they dont move. I re-installed the firmware and got the GPS, and all the raw data to show. Now, for some reason I cant calibrate or see any input from the RC to show.
Before, the PPM led would blink, it would blink faster as I would push the throttle up..
Any clue on this problem??
  • I don't know your RX so - can you check whether you have connected most of the wires to signal, not to the ground? Also you must have +5V and ground from RX to APM. I guess your 3pin leftmost wire on RX is plugged in APM?
  • TX and RX are bound because if I turn off and on the transmitter, I se the led in the rx turn on and off.
  • Mhhh I have just plugged a fresh battery and nothing.. before, the PPM led would respond ( blink faster) as i would push the throttle up!!!
    Would this problem have to do with the firmware or settings?? do i need to reload any software to the APM??
    maybe your 1000mAh battery is too low to power your RC receiver?
