Hello,
I am trying to read 5 light sensors data using the following code. The following code works if I use Arduino Uno board using corresponding digital pin number. However, if I try to use same code for APM2 with corresponding digital pin which is from 0 to 5, it does not work. I am pretty sure that my problem is on the choice of pin number.
Could anyone know what digital pin number should I use? Or, does anyone has a schematic for the APM2 board?
int TSL230_Pin = 0; //sensor output pin
float TSL230_samples = 0.2; //s, higher = slower but more stable and accurate
void setup()
Serial.begin(19200);
setupTSL230();
void loop()
int frequency = readTSL230(TSL230_samples);
Serial.println(frequency);
void setupTSL230(){
pinMode(TSL230_Pin,INPUT);
int readTSL230(float samples){
//sample light, return reading in frequency //higher number means brighter
int readings = 0;
float time_difference=0;
float current_start= micros(); //Return the number of microseconds since the program started
while(time_difference < 1000000*samples)
pulseIn(TSL230_Pin, HIGH); //waits for the pin to go HIGH, return the length of the pulse (in microseconds)
time_difference=micros()-current_start;
readings++;
int freq = readings;
return freq;
