Red Ardupilot and Blue Shield with EM406 GPS
Hi guys.. I am testing my GPS with ardupilot and shield. But I wonder why I could not read any data.
I can only read ""Still Waiting: No Valid Fix"" from the serial monitor.
What are the reasons for this problem?
I tried retrieving the GPS data outdoors but also failed.
Btw, i tried using the RAW_GPS_TESTER and it works.
I am able to read data like A0,A2,0,5B,29, .... ,B0,B3.
But when I moved on to EM406_Tester,
I could not read any data from the serial monitor except "Still Waiting: No Valid Fix"
Any one knows what might be the cause?
This is the defines.h of mine..
// For Alpha Testers only
#define GROUNDSTATION 0 // 0 = Ardupilot GS, 1 = Jason's GS
#define READ_COMMANDS 0 // ground station parser - not finished!
#define REMZIBI 0 // (boolean) use to enable Remzibi - not finished!
// Do not Change below this line
#define WP_10_BYTES 10
// PID cases
#define CASE_SERVO_ROLL  0
#define CASE_SERVO_PITCH 1
// Auto Pilot modes
#define MANUAL 0
#define STABILIZE 1
#define FLY_BY_WIRE 2
#define AUTO 5
#define RTL 6
#define LOITER 7
// Events
#define EVENT_WILL_REACH_WAYPOINT 1
#define EVENT_SET_NEW_WAYPOINT_INDEX 2
#define EVENT_LOADED_WAYPOINT 3
#define EVENT_LOOP 4
// GPS flags
//GPS_update
#define GPS_NONE 0
#define GPS_POSITION 1
#define GPS_HEADING 2
#define GPS_BOTH 3
#define GPS_IMU 4
#define GPS_IMU_ERROR 8
//GPS_fix
#define VALID_GPS 0x00
#define BAD_GPS 0x01
#define FAILED_GPS 0x03
#define WP_START_BYTE 0x18        // where in memory home WP is stored + all other WP
#define MPDEGREE 0.000009
#define BATTERY_VOLTAGE(x) (x*(INTPUT_VOLTAGE/1024.0))/0.000294117
#define HOLD_ALT_ABOVE_HOME 8 // bitmask value
//GPS SIRF configuration strings...
#define SIRF_BAUD_RATE_4800    "$PSRF100,1,4800,8,1,0*0E\r\n"
#define SIRF_BAUD_RATE_9600    "$PSRF100,1,9600,8,1,0*0D\r\n"
#define SIRF_BAUD_RATE_19200    "$PSRF100,1,19200,8,1,0*38\r\n"
#define SIRF_BAUD_RATE_38400    "$PSRF100,1,38400,8,1,0*3D\r\n"
#define SIRF_BAUD_RATE_57600    "$PSRF100,1,57600,8,1,0*36\r\n"
#define GSA_ON   "$PSRF103,2,0,1,1*27\r\n"   // enable GSA
#define GSA_OFF  "$PSRF103,2,0,0,1*26\r\n"   // disable GSA
#define GSV_ON   "$PSRF103,3,0,1,1*26\r\n"  // enable GSV
#define GSV_OFF  "$PSRF103,3,0,0,1*27\r\n"  // disable GSV
#define USE_WAAS   1     //1 = Enable, 0 = Disable, good in USA, slower FIX...
#define WAAS_ON    "$PSRF151,1*3F\r\n"       // enable WAAS
#define WAAS_OFF   "$PSRF151,0*3E\r\n"       // disable WAAS
//GPS Locosys configuration strings...
#define USE_SBAS 0
#define SBAS_ON "$PMTK313,1*2E\r\n"
#define SBAS_OFF "$PMTK313,0*2F\r\n"
#define NMEA_OUTPUT_5HZ "$PMTK314,0,5,0,5,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" //Set GGA and RMC to 5HZ
#define NMEA_OUTPUT_4HZ "$PMTK314,0,4,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" //Set GGA and RMC to 4HZ
#define NMEA_OUTPUT_3HZ "$PMTK314,0,3,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" //Set GGA and RMC to 3HZ
#define NMEA_OUTPUT_2HZ "$PMTK314,0,2,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" //Set GGA and RMC to 2HZ
#define NMEA_OUTPUT_1HZ "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" //Set GGA and RMC to 1HZ
#define LOCOSYS_REFRESH_RATE_200 "$PMTK220,200*2C" //200 milliseconds
#define LOCOSYS_REFRESH_RATE_250 "$PMTK220,250*29\r\n" //250 milliseconds
#define LOCOSYS_BAUD_RATE_4800 "$PMTK251,4800*14\r\n"
#define LOCOSYS_BAUD_RATE_9600 "$PMTK251,9600*17\r\n"
#define LOCOSYS_BAUD_RATE_19200 "$PMTK251,19200*22\r\n"
#define LOCOSYS_BAUD_RATE_38400 "$PMTK251,38400*27\r\n"
And this is the easystar_25.h of mine
 /*ArduPilot 2.5 Header file, good luck!*/
//Hardware Configuration
#define SHIELD_VERSION 1 // Old (red) shield versions is 0 (or 0 = no shield), the new (blue) shield version is 1, -1 = no shield
// Airframe settings
//1-1
#define GPS_PROTOCOL 1 // 0 = NMEA, 1=SIRF, 2=uBlox, 3 = IMU Choose protocol
//1-2
#define GCS_PROTOCOL 0 // 0 = Standard ArduPilot (LabVIEW/HappyKillmore), 1 = special test, 2 = Ardupilot Binary(not implemented), 5 = Jason's GCS, -1 = no GCS (no telemtry output)
#define REVERSE_ROLL 1 //To reverse servo roll, PUT -1 to invert it!!!
//1-3
#define REVERSE_PITCH 1 //To reverse servo pitch, PUT -1 to invert it!!!
//1-4
#define REVERSE_THROTTLE 0 // 0 = Normal mode. 1 = Reverse mode...
//1-5
#define INTPUT_VOLTAGE 5200.0 // (Millivolts) voltage your power regulator is feeding your ArduPilot to have an accurate pressure and battery level readings. (you need a multimeter to measure and set this of course)
//1-6
#define BATTERY_EVENT 0 // (boolean) 0 = don't read battery, 1 = read battery voltage (only if you have it wired up!)
//1-7
#define AIRSPEED_SENSOR 1 // (boolean) Do you have an airspeed sensor attached?
//1-8
#define MIXING_MODE 0 //Servo mixing mode 0 = Normal, 1 = V-tail (v tail not tested yet).
// IR sensors
//2-1
#define ENABLE_Z_SENSOR 0  // 0 = no Z sensor, 1 = use Z sensor (no Z requires field calibration with each flight)
//2-2
#define XY_SENSOR_LOCATION 0 //XY Thermopiles Sensor placement
//Mounted on top:         0 = cable in front, 1 = cable behind
//Mounted on botton:     2 = cable in front, 3 = cable behind
//2-3
#define PITCH_TRIM 0 //(Degrees +- 5) allows you to offset bad IR placement
//2-4
#define ROLL_TRIM 0 // (Degrees +- 5) allows you to offset bad IR placement
// RADIO
//3-1
#define SET_RADIO_LIMITS 1 // 0 = no, 1 = set the limits of the Channels with the radio at launch each time
//3-2
#define SET_RADIO_TRIMS 1 // 0 = no, 1 = set the trims of the Channels with the radio at launch each time
//3-3
#define RADIO_TYPE 0 // 0 = sequential PWM pulses(Fasst, Spektrums), 1 = simultaneous PWM pulses (Corona RP8D1)
//3-4
#define CH1_MIN 1220 // (Microseconds) Range of Ailerons/ Rudder
//3-5
#define CH1_MAX 2043 // (Microseconds)
//3-6
#define CH2_MIN 1041 // (Microseconds) Range of Elevator
//3-7
#define CH2_MAX 1765 // (Microseconds)
//3-8
#define CH1_TRIM 1500 // (Microseconds) This is the resting position for your sticks - 1500 = no trim
//3-9
#define CH2_TRIM 1500 // (Microseconds) Trims are normally set automatically in setup.
//3-10
#define CH3_TRIM 1015 // (Microseconds) Trims are normally set automatically in setup.
//3-11
#define THROTTLE_IN 1 // (boolean) Disables throttle when set to 0
//3-12
#define THROTTLE_OUT 1 // 1 = throttle, 0 = no throttle at all! (good for saving fingers on the bench.)
//3-13
#define FAILSAFE_PWM 950 // must be at least 50 µs less than throttle trim (ch3)
//NAVIGATION: HEADING
//Note: Some Gains are now variables
#define HEAD_P .714 //Heading error proportional (same used to move the rudder)... DO not add too much or you will oscillate left and right.  (drunk driver effect)
//4-1
#define HEAD_I .095 //heading error integrator. Do not add too much or you will overshoot.
//4-2
#define HEAD_MAX 3500 //(Degrees *100) The maximum output in degrees to control the roll setpoint
//4-3
#define HEAD_MIN -3500 //(Degrees *100) The min output in degrees to control the roll setpoint
//4-4
#define HEAD_I_MAX 1000 //(Degrees *100) The maximum output in degrees to control the roll setpoint
//4-5
#define HEAD_I_MIN -1000 //(Degrees *100) The min output in degrees to control the roll setpoint
//4-6
#define XTRACK_GAIN .2 // amount to compensate for crosstrack - use debug mode to find correct value
//4-7
#define LOITER_RADIUS 40 // radius in meters of a Loiter
//4-8
#define REMEMBER_LAST_WAYPOINT_MODE 1 //If set 1 = will remember the last waypoint even if you restart the autopilot. 0 = Will start from zero everytime you restart the system.
//4-9
#define WP_ALTITUDE_RADIUS 10 // (meters) accuracy needed to find our waypoint in meters
//4-10
#define ABSOLUTE_WAYPOINTS 1 // 0 = relative, 1 = absolute - not implemented
//4-11
#define AP_STICK_MIXING 1 // 0 = no mix, 1 = mix
//NAVIGATION: ALTITUDE
//5-1
#define ALTITUDE_PITCH_P 1.5 //Altitude error proportional, pitch setpoint
//5-2
#define ALTITUDE_PITCH_MAX 500 // most the plane will pitch up in degrees to raise altitude
//5-3
#define ALTITUDE_PITCH_MIN -1500 // (Degrees *100) most the plane will pitch down in degrees to lower altitude
//NAVIGATION: SPEED GAINS
//6-1
#define ALTITUDE_THROTTLE_P 1.33
//6-2
#define ALTITUDE_AIRSPEED_MAX 15 //(0-125) Maximum extra speed for gaining altitude
//6-3
#define ALTITUDE_AIRSPEED_MIN -15 //(0-125) Maximum reduded speed for loosing altitude
//ATTITUDE: ROLL GAINS
//7-1
#define ROLL_P .65 //     START WITH THIS VALUE TO TUNE - overall proportional term determins how much rudder you use to turn
//7-2
#define ROLL_I .4 //    roll PID integrator
//7-3
#define ROLL_Ps .6 //    Controls rate of rudder turn - direct proportional effect; value of 1 = no dampening
//7-4
#define ROLL_Is .2 //    Controls rate of rudder turn - speed at which the non proportional effect happens - .2 = 5 seconds
//7-5
#define ROLL_MIN -2500 //maximum output of Rudder
//7-6
#define ROLL_MAX 2500 //maximum output of Rudder
//ATTITUDE: PITCH GAINS
//8-1
#define PITCH_P .65 //    Pitch Proportional
//8-2
#define PITCH_I .35 //    Pitch integrator
//8-3
#define PITCH_COMP .30 //<------Very important, Pitch compensation vs. Roll bank angle.
//ATTITUDE: THROTTLE OUTPUT GAINS
//9-1
#define THROTTLE_ABSOLUTE 3 //Absolute
//9-2
#define THROTTLE_P .32 //Proportional
//9-3
#define THROTTLE_I .04 //Integrator
//9-4
#define THROTTLE_I_MAX 50 // (0-125) 50=70% Integrator limit.
//9-5
#define THROTTLE_CRUISE 25 // (0-125) %throttle, or (int)target airspeed for cruising
//9-6
#define THROTTLE_OFFSET_MAX 35 // (0-125) 70 = 56% maximum throttle
//9-7
#define THROTTLE_MAX 60 // (0-125) 70 = 56% maximum throttle
 /*Debugging Stuff*/
//10-1
#define DEBUG 0 // 0 = no debugging, will cause plane to enter debugging simulation mode
//10-2
#define TURNRATE 55 // (degrees) how fast we turn per second in degrees at full bank
//10-3
#define CLIMBRATE_UP 1000 // (meters * 100) how fast we climb in simulator at 90°
//10-4
#define CLIMBRATE_DOWN 3000 // (meters * 100) how fast we climb in simulator at 90°
//10-5
#define OUTPUT_INFO 1 // set to 0 to avoid printing telemetry out - Tester only
Darren, http://diydrones.com/forum/topics/darrens-project?xg_source=activity
  • Are my readings normal?
    Are these values read from the serial monitor correct?
    Are these values accurate?
    If the alt is altitude, why does the values changes so much?
    and I am somewhere level 6, which means cannot be 70metres above the ground.
    How does GPS read ground speed?
    What version of the code are you using?
    Is your GPS module's red LED on?
