Relay or making one pin 5v on 2.5 Ardupilot
I need to switch led On/OF form autopilot, in every 5 min (without radio).
If i managed to change code(arduplane 2,65)  to make: relay_on() relay_off() every 5 min , then what PIN dose that correspond to?
Or how can i make costum PIN output? (for relay, or optron)
    One way would be to use jD-IOBoard that already supports MAVLink to driver relays and other things. I think I will make driving relays optional on next firmware for it. IOBoard have full support for ArduCopter and MAVLink protocol.
    jD-IOBoard v1.0, MCU controlled IO Board for driving LEDs, Relays, Servos
    R/C UAV and ArduCopter manufacturer and one stop shop. We make your FPV come true.
  • You can easily change that 3 functions to alter the pin of your choice. Then just upload your custom firmware to APM.
  • Hello Mell,
    I found this in the system.pde:
    #if CONFIG_RELAY == ENABLED
        DDRL |= B00000100;     // Set Port L, pin 2 to output for the relay
    #endif
    This is Digital pin 47
    In the Eagle files I could find any connection to this pin !
    I'm afraid this connection is cancelled on the APM2 and APM2.5 boards !
    I think it's easier and more safe to use a Arduino Nano board or similar.
    Nano V3.0 board
