  • I'm having problems with Geo Fence.
    When I'm in a mission the hex will often fence breach at the first waypoint and then RTL. Sometimes it will make it past the first waypoint to fence breach later in the mission.
    I set the breach limit to 800m distance and 140m altitude, to make sure I don't go past the fence and I still get the message and the systems still RTLs.
    I've added the graphs from the Telemetry Logs (Altitude in GLOBAL POS & GPS_RAW_INT) and the .kmz file of the flight.
    Altitude log files show a spike in altitude right before Fence Breach, but I didn't see any spikes in altitude and the .kmz file confirms this.
    What's going on and how can I keep this from happening? It's very important that stop this from happening. Any help would be greatly appreciated.3702578940?profile=original3702707892?profile=original
    20150708191417.tlog.kmz
    https://storage.ning.com/topology/rest/1.0/file/get/3702579257?profile=original
  • My fix is not the ideal way but it appears to work. I go into the "Full Parameter List", then edit the "FENCE_TOTAL" number and set it to 0, then press "Write Params". The geofence still appears on the mission planner but if you press try to download the current geofence (right click > geofence > download), Mission Planner reports that there is nothing to download. Like I said, you can still see the geofence in Mission Planner, but the autopilot will not recognize it. I was also having issues uploading a new geofence. In order to upload a new one, I go into the "Full Parameter List", then edit the "FENCE_ACTION" and set the value to zero. I then create a new geo-fence. When you press "Upload", the old fence will clear away. Then I go into "FENCE_ACTION" and set it back to 1,2, or 3, depending on which option I want. You can double check that the APM is using the correct fence by going into (right click > geofence > download) and making sure you still see the geo fence you want.
    Thanks.
  • Bump. I can't figure this out either. Where is the Software Tab?
    Thanks.
  • Anyone??? :)
DIY Robocars via Twitter
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
