Reversing yaw correction direction?
Hello DIYD,
I have received my APM 2.5 yesterday, installed it in my hexacopter and loaded firmware (newest firmware via the mission planner).
The problem that I'm having is this:
The wiki states that the motors should spin in a certain direction (I'm running hexa +):
FRAMES_all_hexa_octa_y6.jpgSince I had MultiWii before on this copter, my motors are soldered to spin the exact opposite direction.
Is there a way to reverse the direction in which the APM corrects yaw? I would really like to avoid re-soldering 12 connections.
Cheers,
Jonathan
  • Hi Jonathan,
    You can edit libraries/AP_Motors/AP_MotorsHexa.cpp , and compile your own firmware. Just switch all the "CW" and "CCW." Sorry if this is too late to be helpful!
    Aaron
  • Admin
    @Johnathan,
    Some ESCs can be programmed to reverse the motor direction without having to rewire your motor connections.
    Regard,
    TCIII Admin
