RFD900, RFD900+ - New long range radio modem
Hi All,
I would like to introduce you to a new radio modem that we developed for very long range datalinks!
http://rfdesign.com.au/RFD900.php
Some of the key features of the RFD900 are as follows:
  • Multi point and point to point link capability.
  • Long range >40km depending on antennas and GCS setup.
  • 2 x RP-SMA RF connectors, diversity switched.
  • 1 Watt (+30dBm) transmit power.
  • Transmit low pass filter.
  • > 20dB Low noise amplifier.
  • RX SAW filter.
  • Passive front end band pass filter.
  • Open source firmware / tools, field upgradeable, easy to configure.
  • Small (30 x 57 x 13 mm), light weight (14.5g).
  • Compatible with 3DR / Hope-RF radio modules.
  • License free use in Australia, Canada, USA, NZ.
These modems are designed to support long range applications, while being easy to use and affordable.
These modems have been flying in various platforms and have demonstrated excellent performance in real applications.
RFD900 modems are now available at: http://store.rfdesign.com.au
Support within APM planner and the radio configurator from Michael Oborne is already available.
It works seamlessly with APM planner, all radio Mavlink parameters are available.
Update, December 2014:  The RFD900+ with improved specifications is available now at:
http://store.rfdesign.com.au/rfd-900p-modem/
Seppo Saario
rfdesign.com.au
      • Ivan, He stated supply wires, meaning +5 an - .
        What he is saying is a good Ideal, if you have long + an - wires to the 900 it is easy to pick up static electricity  and that can cause problems.
        Put the capacitor right at the plug of the 900 across + an - , the capacitor most likely will have a - sign at one lead , solder that to the - power wire and the other lead of capacitor to the + wire.
        If your not aware, capacitors are design to knock down static pulses.
        You can most likely pickup a 100uf 15volt Cap.at Radio Shack or a local Electrical Supply store.
        I haven't done that yet either, but I will get right on it tomorrow.
        CAP.AT steht zum Verkauf
        • You're right about the cap installation, James.
          If there's too much voltage drop when the modem transmits and the voltage spikes below something like 4.9V, it may upset it.  You cannot tell just by using a voltmeter - you need an oscilloscope to see the fast voltage transients.  But no need to mess with an oscilloscope - just install the capacitor or connect a sufficient power supply with very short, thick wires to find out if it makes the problem go away.  A 10 volt cap is sufficient and probably 47uF would be ok, depending on the length and size of your +5V & GND wires.
          But, again, you can also quickly and easily check if this is the problem simply by setting the transmit power to its lowest setting because then the voltage drop should be negligible - even if the wires are long and thin.
  • Hi,
    Thank you for the answer. However, unfortunately I have still not been able to make any of my RFD868+ modems to work and would be happy for any further input. Is anyone using the RFD868+ successfully?
    I checked the firmware on my modems and they are SiK 1.13 (which is newer than the one that may be downloaded from the RFDesign website)
    Today I tried two 3DR radios and connected them both to my computer. The green led is solid green on both of them and the communication works perfectly. (I had two cutecom consoles open and were sending messages back and forth with no problem)
    But if I instead connect two RFD868+ modems the same way the connection is constantly dropped every now and then. I set up the modems the same way as the 3DR radios as follows:
    0:FORMAT=26
    1:SERIAL_SPEED=57
    2:AIR_SPEED=64
    3:NETID=30
    4:TXPOWER=20
    5:ECC=1
    6:MAVLINK=1
    7:OPPRESEND=1
    8:MIN_FREQ=868000
    9:MAX_FREQ=869000
    10:NUM_CHANNELS=10
    11:DUTY_CYCLE=100
    12:LBT_RSSI=0
    13:MANCHESTER=0
    14:RTSCTS=0
    15:MAX_WINDOW=131
    I would really appreciate any help
    Best
    Carl
  • This reply was deleted.
    • Hi Thomas, did you ever resolve this? I have the same problem between a 3DR compatible radio and an RFD900+
  • Hi All,
    Has any body tested the new RFD868+ ?
    This may be a stupid question but will the 1w 868MHz have the same range as the RFD900+ (1w)?
    Will the 900MHz GSM band interfere with the RFD900+ or vise versa?
    Cheers,
    RS
  • Dear all,
    I have a connection problem with my RFD868+ modems and I am looking for some input on how to solve the issue.
    - If I connect two RFD868+ to my computer via FTDI cables the connection is solid between the two.
    - If I instead connect one of them to a Pixhawk (on TELEM1 connector) and monitors the connection in QGC the connection is lost every 3rd or 4th second.
    - The connection drop is very regular, but the connection is regained after approx. 2 seconds.
    - It does not matter if I power the pixhawk via USB or 5V BEC.
    - It does not matter if I power the radio modem directly from the Pixhawk or from 5V BEC.
    - It does not matter if I replace both the RFD868+ modems with a second pair.
    - If does not matter if I lower the amount of data transmitted from the Pixhawk.
    - If I instead replace the radio modems with 3DR 433 MHz modems the connection is solid without any drops.
    The configuration of the RFD868+
    0:FORMAT=26
    1:SERIAL_SPEED=57
    2:AIR_SPEED=64
    3:NETID=25
    4:TXPOWER=20
    5:ECC=0
    6:MAVLINK=1
    7:OPPRESEND=0
    8:MIN_FREQ=868000
    9:MAX_FREQ=869000
    10:NUM_CHANNELS=10
    11:DUTY_CYCLE=100
    12:LBT_RSSI=0
    13:MANCHESTER=0
    14:RTSCTS=0
    15:MAX_WINDOW=131
    The configuration of the 3DR 433 MHz modems
    S0:FORMAT=25
    S1:SERIAL_SPEED=57
    S2:AIR_SPEED=64
    S3:NETID=25
    S4:TXPOWER=20
    S5:ECC=1
    S6:MAVLINK=1
    S7:OPPRESEND=1
    S8:MIN_FREQ=433050
    S9:MAX_FREQ=434790
    S10:NUM_CHANNELS=10
    S11:DUTY_CYCLE=100
    S12:LBT_RSSI=0
    S13:MANCHESTER=0
    S14:RTSCTS=0
    S15:MAX_WINDOW=131
    3702073609?profile=original
    I would really appreciate all help.
    Best Regards
    • I am trying to find the source of the connection issues, do someone know the answer to the questions listed below or where I can find them?
      1) Sometimes when I power up the modems the green led is completely off and the red is constant on. I think this means firmware update mode, why is this happening?
      2) When the connection is lost the green led on the modems start to flicker, is this "normal" behavior for packet loss or is it an indication of something else?
      3) According to the manual you may use the modem with one antenna. Do I need to terminate the second antenna connector with a 50 Ohm impedence or just leave it open?
      Thank you very much,
      Regards
      • 1) If the Red led stays on you will have to update the firmware, goto RFDesign.com and Download;
        RFDtools-v1.6.zip
        RFDsik-v1.12-RFD900p.ihx  (Latest Firmware)
        Install the RFDtools and put the RFDsik-RFD900p.ihx in the same folder/directory, and run the RFDtools and install the Firmware from the RFDtools.
        2) the green led  On it is connected between the Base and Plane modems.
        3) the modems will work with one antenna and you do not need to terminate the other antenna connection, but it is best to use both antenna's
        You'll have to connect each Modem to the usb cable to Laptop to update Firmware, most likely the old firmware will be 1.9 version.
        At the bottom of the RFDtools there are three boxes that needs to be checked,
        ECC
        opResend
        Mavlink
        If you are connecting to Pixhawk.
        I could not get the mavlink to connect using MissionPlanner, I had to install APMplanner .
  • Got mine already wired in to a 3DR Pixhawk, but connecting to the usb cable to Laptop on Base station it connects at Com Port 6 57600 but I get a error message saying;
    "Failed to load Command Mode"
    And the Led on the 900+ stays Solid Red.
    What's happening ??
  • Hi Carl,
    I've never added a special ground plane. The cable shield acts as one half of the antenna so that, although it's called a monopole, it's really a dipole. If the antenna and cable are mounted so that they are in-line, the radiation pattern will be fairly omni-directional. But for your antenna, the cable is probably at a 90 degree angle to the antenna which is going to have a lopsided pattern that's stronger in some directions than others. I've always used tranceivers that have two diversity antennas like the RFDs and mounted them at 90 degrees to each other with one vertical and one aligned horizontally along a wing. This has given very good reception regardless of the plane's orientation to the ground station. If you do add a ground plane, then I would think it would be best to mount two of those antennas at 180 degrees from each other, on opposite sides of the ground plane. But I don't know why go to all the trouble (plus add the extra weight) when there are easier ways to do it.
