ROI being ignored.
After reading every post I can find and playing around with parameters I've had no luck getting my copter to yaw towards a ROI.
I'm running 2.9.1 on a 2.5 Mega board with Mission Planner 1.2.32 mav 1.0.
I loaded a simple WP Mission and between WP2 & WP4 put point 3 as the ROI. I would have thought the copter would have 'looked' at the ROI point while traversing between the two waypoints.
What am I doing wrong? Am I missing an input in the parameter boxes next to the command?
  • Hi all,
    I have a similair problem and im searching probably in all the wrong places for the solution.
    Im trying to create a mission where the quad will face the ROI.
    It will not do it whatever i try.
    Im using mission planner 1.2.62, and firmware 3.01.
    There is no option YAW_OVR_BEHAVE in the adv. param list.
    Is there anything i am missing?
    Should i download older firmware maybe?
  • Bumping ROI thread:
    Any one succeed to test the ROI using v3-R5 or earlier?
    The ROI failed on my quad, and it not point the nose to ROI location.
    Any suggestion?
    Thanks.
  • It is too bad that ROI, that was working in 2.8, it is not working anymore in 2.9
    Anyway you can have back some of ROI function setting YAW_OVR_BEHAVE mavlink parameter  to 1
    If you set YAW_OVR_BEHAVE=1 after ROI command YAW will point correctly to the ROI location (as before).... but before issuing ROI Command YAW doesn't point to the next WP.
    Luciano
