Hello,
i just wanted to make sure that i did not mess up something in my frame configuration (direction e.g.). On my first flight i realized, that roll und pitch were reversed (horizontal stick movement was pitch and vertical roll). I solved the problem by switching the yellow and white cable on the apm which worked fine. Now i am a little bit doubtful if this is the best solution or if i did something wrong with the frame configuration ...
Do you have any hints for me?
thanks a lot,
tm
