HelloI am in the progress in building a full replica shadow 200, with a 4.27 wingspan.Its soon done in in the first weeks of fine tuning I am just driving it on normal RC system.I am interested in having some sort of UAV/FPV system where it can be totally autonomous and i can go on it and se live picture from the dome I am placing underneath but i will also be able to override the UAV and control it like a FPV I also want to control it from my computer. I also wonder about the communication system, since all this can be transfered via a data link i can use WIFI but does anyone know about some sort of Satellite modem, as I have a full replica so space and weight is no problem, does anyone have any ideas of what kind of system I should get...Best RegardsKristoffer Larsen
There are numerous satellite phones that you can use to make a data link similiar to a cellphone connection. They are available for anywhere from $600 to $3,000 each plus purchasing a data plan. Not cheap, but possible.. Also, since you are looking at a 1:1 replica what are you using as your construction materials? The original is metal and is over 200 pounds empty weight. But if you look toward fiberglass you could make the same size for around 15-20 pounds max. Which not only frees up more weight for all the controls/sensors/accessories, but it will also limit your liability if you should ever crash into someone else's house, car, or other property... Just a thought...
I am a ex UAS Operator for the army and I am very interested in making a replica of the Shadow 200 now that my life involves Home Depot and not AR's, Chow Hall, and Arial Drones. Is there any chance i could get a cross section of this plane if you have it, it would make designing this from scratch not nearly as complicated. Email me at dave.james.white@gmail.com if this is doable and if not i wish you the best of luck.
hello,
