  • You have RTL enabled for your battery at a voltage of 10.5 volts and a mAH of 983. It appears you tripped it based upon voltage.
    • Hi Tom - Thanks for that - I will recalibrate my voltage sensor as the battery is nowhere near that. Thanks man!
      • Do you think those are conservative levels for the battery failsafe? I want to leave some room for RTL mode to complete without damaging the battery...
        • Personally I try to be in process of actually landing when I hit 3.5 volts per cell (10.5 for 3S). 10.8 volts gives some margin to return. Since I use an OSD I monitor the voltage myself and have my battery failsafes turned off.
