Rudder Travel
Hi guys,
I'm trying to change the min and max for the tail servo. But I can not do it. The value is returned to the 1500 value.
Please, how to fix it?
3691338353?profile=original
  • Thanks for the help!
  • Hi Igor,
    basically you need to tell the FC the radio range (RC...) and the setup of your helicopter (H....).
    'Radio Calibration' sets the RC4 values similar to these:
    RC4_DZ,5
    RC4_MAX,1934
    RC4_MIN,1094
    RC4_REV,1
    RC4_TRIM,1514
    The helicopter specific values start with H(or H_) depending which version you use. In 3.3 you get/set something like:
    HS4_MAX,1929
    HS4_MIN,1099
    HS4_REV,1
    HS4_TRIM,1520
    You can change all parameters in 'Full Param List/Tree'.
  • Hi,
    Unfortunately, this parameter does not fit.
  • Try Full Parameter List/Tree and check RC4 limits
