Please forgive what is probably a very novice question regarding the configurator, RC aircraft, and the Arudcopter.
I've attached my Arducopter to the configurator to re-confirm my sensors, calibration, etc.
I've completed the Arducopter wiki Pre-Flight Test and everything is working well. My question is this:
When I move my rudder/yaw stick left or right, the motor controls shown in the configurator respond appropriately, but when I let go of the stick it springs back to the center position and the motors stay at the earlier position. In other words, they maintain the yaw. It seems to me that would cause my Arducopter to continue to yaw even after I've let go of the stick (and it's sprung back to the center position). In order to stop the yaw, I need to push the stick to the opposite side and make little adjustments until I get the motors re-centered again.
Is this normal and desirable behavior for RC? If so, I'll learn to fly it that way. Or is this something I should change? If so, how?
Reference Info: I am using a T10CHG Futaba Transmitter in basic H-1 Helicopter mode. The yaw/rudder stick is on the left and springs back to the center (unlike the Throttle, which stays where you put it).
So with rudder stick you command your quad to rotate it's "nose" heading either to turn to left or right.. Not absolute direction. Just like in airplanes, if you give rudder, it start to turn and when you release rudder it will continue new selected heading.
