This thread is to discuss the details of getting SITL running on Windows as documented on this wiki page.
Menno,
3) Try setting ARMING_CHECKING to 0 to disable all the arming checks.
6) You'll need to use the virtual ch5 switch. So set the FLTMODE1 parameter to the number of the flight mode you want and then type "rc 5 1000". if you want to use another flight mode switch position you can see the pwm range in comments above the parameter at the link provided.
Menno,
Ok, my guess is that the sim_arducopter_randy.sh doesn't look fro the "--viewerip" command on the start line. Instead you probably need to update the script itself. At the very bottom of the script you'll see a line like below and the bit that is highlighted should be replaced with your IP address.
mavproxy.py --master tcp:127.0.0.1:5760 --sitl 127.0.0.1:5501 --out 127.0.0.1:14550 --out 127.0.0.1:14551 --out 192.168.1.13:14550 --console --map --aircraft test --quadcopter $*
Menno,
You should be able to send commands from the MP to fly-to-here, etc.
Wind is also there. if you enter a command like this it will show you the values of all the simulator-only parameters:
param show SIM*
Chrstine,
It's saying that it can't find the autotest.py script for some reason. Maybe go into the ArduCopter directory (i.e. GitHub/ardupilot/ArduCopter) and try running the command but put an extra dot at the beginning. i.e. ../Tools/autotest/..
maybe it's a file format issue difference between windows and unix. Could you go into the autotest directory and try running:
dos2unix autotest.py
or maybe this command to convert all dos formats to unix formats.
dos2unix *.py
Tridge and I reviewed the two wiki pages that we have (sitl on windows, sitl on linux) and added some details to both. It seems that to run ArduPlane you also need to install, "autogen" and "make" the JSB simulator.
Can you give the modified instructions a try and see if you can get it working?
Parth,
Ok, I've reproduced the issue although I don't immediately know the solution. I think it's related to the scripts being meant to run on Unix and some features of the filesystem don't work when it's running on the Ubuntu VM. We use to have a similar issue for copter but we added some checks around lines starting with "os.". I've ping'd Tridge who may be able to help sort it out (he's the author of SITL and many other things).
HI, newbie problem !
I follow the instruction at:
http://dev.ardupilot.com/wiki/settraing-up-sitl-on-windows/
reached to the place I tries to run the autotest.py:
./Tools/autotest/autotest.py build.ArduCopter fly.ArduCopter logs.ArduCopter --map
but all I get is command not found !
I tried to cd to the directory , and could see the code using vi autotest.py
what am I missing
Itay
I've two question please:
1) there's a way to connect the Planner via TCP to the simulation in progress?
I managed to do that through jsbsim of course, but it would be nice to do that while the script is running
2) is possible covert a tlog or flashlog for running my flight inside SITL, like the telemetry log inside the Planner?
Rob said this:
I needed to do the following to get the compilation process started:
cd ardupilot/ArduCopter
make configure
cd ..
python ./Tools/autotest/autotest.py build.ArduCopter fly.ArduCopter logs.ArduCopter –map
It ran through a few tests, but I never saw a map. But but I got this error message at the end (which may be normal):
File "/usr/lib/python2.7/dist-packages/pexpect.py", line 836, in read_nonblocking
raise EOF ('End Of File (EOF) in read_nonblocking(). Exception style platform.')
EOF: End Of File (EOF) in read_nonblocking(). Exception style platform.
>>>> RUNNING STEP: logs.ArduCopter at Mon Dec 9 21:43:24 2013
Dumping logs for ArduCopter
Starting sketch 'ArduCopter'
Starting SITL input
bind port 5760 for 0
Serial port 0 on TCP port 5760
Waiting for connection ....
navigating menus
Saved log for ArduCopter to /mnt/hgfs/3drobotics/buildlogs/ArduCopter.flashlog
>>>> PASSED STEP: logs.ArduCopter at Mon Dec 9 21:43:26 2013
It could be that the pyexpect is in dos format when it needs to be in unix format. running dos2unix on the file might fix it.
When I set-up Ubuntu as part of creating that page I also found that the map didn't appear initially but then magically a day later it started working. While I was working through the problem with Tridge he asked me to do this:
mp_slipmap.py
This brought up the map for me. He then asked me to do these two:
sudo pip install --upgrade pymavlink
sudo pip install --upgrade MAVProxy
the first one didn't do anything but the 2nd one did do an upgrade which surprised me because I thought that I'd done that as part of Step #4.
1
2
3
of 3 Next
