Hi!
This is probably a stupid question, but I’m a virgin in this field
I just received rtf without rx from 3d robotics, I am using my Fly Sky fs-th9x I have 6 single wires for mu RX GREEN, YELLOW,ORANGE,BLUE,WHITE,RED. and a black red for power
Those any one knows to which channel do they go ?
I was looking at this schematic but it’s a bit confusing to me
http://code.google.com/p/arducopter/wiki/AC2_Radio
Thank you
Luis
Hi Guys
Just to give you an update I finally got it working, I really don’t know what it was but after rewire everything I got the ESC’s to work. (there was probably something not connected right ) I was assuming that 3DR will test it before sending it out.
Now I can start the rest of the programing.
Luis
Ok I finally ot it to work
but now I am having problems I can not arm it and also I can't set the modes with the swithces
Luis
Ok thanks
one more thing
They go into the signal pin of the RX?
Luis
Thank you for that quick response
Sorry that I made myself clear.
I have a total of 6 wires for my RX my question is : where should I plug them in my RX ? In the Signal side? And the other question is how can I tell which channel is which ?
I have the 2.5 APM
Here are some pictures
Your link is to the older APM1 controller. Is that what you have?
I suspect you have APM2.5 if the aircraft is new.
HERE is the same section for APM2.5
-=Doug
i dont really understand what you are saying. So all you want to do is connect the RX to the flight controller? Can be a bit more specific on what you have? gear and leads...
sorry i cant help more
