RX instalation
Hi!
This is probably a stupid question, but I’m a virgin in this field
 I just received rtf  without rx from 3d robotics, I am using my Fly Sky  fs-th9x I have 6 single wires for mu RX GREEN, YELLOW,ORANGE,BLUE,WHITE,RED. and a black red for power
Those any one knows to which channel do they go ?
I was looking at this schematic  but it’s a bit confusing to me
http://code.google.com/p/arducopter/wiki/AC2_Radio
Thank you
Luis
  • Hi Guys
    Just to  give you an update I finally got it working, I really don’t know what it was but after rewire everything I got the ESC’s to work. (there was probably something not connected right ) I was assuming that 3DR will test it before sending it out.
    Now I can start the rest of the programing.
    Luis
  • Ok I finally ot it to work
    but now I am having problems I can not arm it and also I can't  set the modes with the swithces
    Luis
  • Ok thanks
    one more thing
    They go into the signal pin of the RX?
    Luis
  • Thank you for that quick response
    Sorry that I made myself clear.
    I have a total of 6 wires for my RX my question is : where should I plug them in my RX ? In the Signal side? And the other question is how can I tell which channel is which ?
    I have the 2.5 APM
    Here are some pictures
  • Your link is to the older APM1 controller. Is that what you have?
    I suspect you have APM2.5 if the aircraft is new.
    HERE is the same section for APM2.5
    -=Doug
  • i dont really understand what you are saying. So all you want to do is connect the RX to the flight controller? Can be a bit more specific on what you have? gear and leads...
    sorry i cant help more
