Sensor data not showing in flight data
When I plug the APM to the usb and connect via COM3, i go to Flight Data and can't see any information. I have the switch on 1  ( away from pins) and nothing comes up...
Any solution??
  • Thank you Mike... Im getting  bigger batteries.. if you siggest some please do.
    As far a s calibration.. yes.. i did the manual calibration on channel 3.. and when pluged like that. the motor works.
    Props are off!!!
    What would the APM invalid input means?? What should I do??
    what version of APM Mission Planner?
