Sensor Fusion Limitations & Razor
Hey!
I bought a SparkFun 9DOF Sensor Stick some time ago and everything is working fine with an Aduino and the Razor code, that uses the DCM algorithm to calculate the pitch/roll/yaw. However, I find that the YPR calculations are not accurate when I move the sensor really fast in x, y or z axis. So my first questions is: Is it possible to have accurate pitch/roll/yaw calculations when moving the sensor fast?
My goal is to have a sensor connected to an Arduino that can send pitch/roll/yaw calculations with a reasonable accuracy in a high speed/acceleration scenario (i.e. mounted to a racing drone). Can anybody help me with:
  • What IMU can I use? I was using the SparkFun 9DOF but it is not longer for sale. I wouldn't mind changing, as long as it has SPI or I2C to interface with an Arduino.
  • What algorithm can I use? The DCM used in Razor seems to be good, but as I explained I'm not getting accurate measurements when having acceleration along x,y or z axis.
  • What about Kalman filtering or complimentary filter? What are they limitations?
Thank you!
  • ok, now we come to the heavy part.
    you might consider switching over to an arm derivate as mcu.
    the madgewick sensor fusion is somewhat more optimised.
    give google a try.
    7ms is very very slow for fast movements.
  • run the sensor fusion with new data all 2ms.
    that should help.
