i am getting a lot of servo jitter on my middle switch. i have them setup as
#define POSITION_1 MANUAL
#define POSITION_2 STABILIZE
#define POSITION_3 FLY_BY_WIRE_A
manual is fine, rock solid
i get a lot of constant jitter and twitch on stabilize and the imu is very still
and a little bit not as bad jitter on fly by wire
i have tried the servo optocoupler im an not 100% sure i am using it correct.
i put it between the RX and the ardupilot board and i am still getting jitter, i tried between the ardupilot board and the servo's and it kills everything, no movement from anything on any switch position.
i am running a 3cell 11.1v 5000mah battery from the ESC through the ardupilot board then onto the RX.
the wirediagram is where i put the servo optocoupler the orange square.
a few other pictures without the servo optocoupler attached.
If you use the optocouplers, you need an independent power supply for the servos. That's why they don't work on the board to servo side.
Please upload your config file and I'll try to diagnose your setup.
