Hi all!  Thanks for all of the help you have already lent me in getting started with my 3DR Y6.
The Pixhawk is looking for mode selection information to come to it via Channel 5, where it is finding my gear switch.  How do I get Pixhawk and the DX7 to cooperate to use the 3-position Flaps switch for mode control instead?  I'm using a Spektrum Satellite receiver, so I can't just swap some connectors.
I'm using MissionPlanner.  I tried qgroundcontrol, because I noticed it has channel numbers in the advanced radio calibration screen. However, I was not able to modify those, and they all just remained set to "1".  I also didn't have any options in the "select controller" dropdown box.
Thanks for the help!
Brian
  • Hey, im not sure if you ever got six modes figured out, but I did using my DX7 Heli, using the 3 pos flight mode switch and gear switch.... here is what I used for mixing.
    D/R switch select : comm rudd
    input select Aux 2: Inh / Aux2 trim :Inh
    Flap : System / Flap Trim: Inh
    Under Travel Adjust I set Gear to +93% and -10%
    Under Flap Sys I set
    Norm Up 100%
    Mid Dn 50%
    Land Dn 100%
    Then under Program Mix 1 I set
    Flap->Gear  On
    Rate: -20%
             +65%
    SW: on
    Offset: 0
    You may have to play with the travel adjustment while in Mission Planner flight modes, but these settings worked for me, now my DX7 and Spektrum satellite rec. are working great with my 550 Carbon Bumblebee quadrotor.... It took me quite a while to figure this out, and I tried a bunch of different guys mix's with no success before stumbling on this. Hope this helps someone out there!
    Ginnz!
    • Thanks.  Good info.
      I got 6 modes working, but I was after the elusive 7th channel.
      • yep, im there too now. six modes are fine, but id like to set up auto tune to work with the aux2 switch. and i have a turnigy receiver controlled on/off switch. basically a relay. id like to be able to turn off/on LED's.... im thinking i should be able to program one of the unused servo pins to act as AUX2? im only using pin set1 to control my gimbal tilt servo, to keep the camera level in flight. i dont have it set up to manually tilt or anything. all the other pins are free, except pin6, which the CC Bec is plugged into.... If i was using a standard receiver, with AUX2 plug, it would be easy, but im using the Spektrum satellite receiver.
        anyone?
        Ginnz.
  • So which person, or which group is the right one to contact with Pixhawk development questions?
    • have already made the change in the code to add RCMOD_ for FLIGHTMODE, TUNE,AUX1 and AUX2
      I have also tested it and it works.
      Im waiting for response from the core developers and hopefully it will be merged and made public in the next release.
      In the mean time if someone wants the .hex file im happy to supply it without any guarantee what so ever :)
      it's based on the latest developer code and may contain serious faults since there is quite a bit of new untested features coming out.
      • hey I've come across this thread because im trying to setup my DT7 and DR16 with a pixhawk quadcopter, I have already tried opening up the transmitter and swapping the channels round however the wrong pwm outputs were broadcasted because i'm trying to swap the gimbal pitch control (Broadcasted as channel 5) with the flight mode switch (channel 6). I have searched through the parameter list on mission planner and i cannot find any of the variables you mentioned. Have they been renamed? Or did the development team ignore your idea? Thanks! It would also be great to some how still use the gimbal pitch control if that is at all possible....
        Thanks Again! Henry
      • I'm relatively new and noticed that what you posted last year concerning multiple flight modes are the troubles I*'m currently having with my DX9.
        Do you know if the feature you suggested (RCMOD_ for FLIGHTMODE) has been incorporated into the Pixhawk firmware? If not is it possible to get a copy of your HEX code (and brief description).  :)
        Thanks,
        rotor56
      • Well that's just pretty awesome!  Thanks!  I'll plan to wait for the release, I think.
        I would imagine modifications like this don't instantly make it into Mission Planner.  Is there a guide somewhere to setting parameters like this that aren't available in the GUI?  ...or will every parameter show up immediately in MP somehow?
        • They appear in mission planner without description or any info what so ever but you can still use them
          • Excellent.  Can you give me a quick rundown on how it would need to be set to allow flight modes to be set by the Channel 6 (RC6) coming in from the Spektrum?
            I would also hope to see RC5 in the list of channels available to use as a pass-through or to appear in the list of inputs for camera pan, roll, and yaw. I currently use the Gimbal configuration to set incoming RC7 to control output RC9, with MP thinking I'm using that to control camera roll.  I'm really using it for an RCCC Camera switch.  I would like to use RC5 for camera pan.
            Any idea of the timeframe for the next release (a month versus 6 months sort of estimate, maybe?)
            I appreciate your help with this.
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
sam liked Jimmy Oliver's profile
Aug 25
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
