Setup Problem using the APM Mission Planner
I'm trying to configure my APM for quadcopter use using the APM Mission Planner.
I've been through the documentation and set up the COM ports as instructed and have the CLI slider switch toward the servo headers.
When I lauch the terminal in the APM Mission planner, I get the following response:
3690866828?profile=original
The APM mega board has all three leds lit ie red, amber and blue and the oilpan shield has a blue light lit. When I launch the APM Planner the TX and RX LEDs flash.
My PC is running windows 7 Ultimate and the FTDI drivers seemed to install correctly and without incident.
I'd be interested to hear anyone's thoughts on the possible cause of this so I can get it fixed.
Many thanks in advance,
Tim
  • Hi Tim
    Were you able to solve , i have 100% the same issue....
    Regards
    Anton
    try 57600 and 38400, depending on what quad software you are using.
    please check your baud rate, id guess it is set wrong
