Share parameters to help others tune
Does anybody know the parameters of the 3DR Quad kit? http://store.3drobotics.com/products/diy-quad-kit
I have assembled mine and attached a 3s4000mAh Lipo, carefuly balanced, but I can't get it off the ground in "Stabilize mode" and I don't want to hold it with my hand above the ground.
Thanks a lot!
  • T3
    When you load the firmware it automatically loads the default parameters.
    • Thankyou. I am asking because mi Quad jerks, the black 3DR 2836 motors are horrible.
      When they are tightened to the frame, the motor does not turn,
      they require thin washers wich are not supplied, and with or without washers, the screw wears out,
      I guess that it will be useless very soon.
      I also got three bad ESCs in the kit, really,  I don't want to waste my time on the ill designed mechanics, of this supplier, from now on, I want to work with the quality parts other people are using.
