Skyfun UAV build
Well, after a long time in the theoretical world, I decided it's time to see how APM works in reality, so I splashed some cash and ordered this and a bunch of other parts from Hobby King:
3690996258?profile=original
At this point, my MS Excel OCD set in and I felt the need to figure out how I could package everything and still achieve a good CoG position.  Taking the front of the launch finger holes as the published "ideal" CoG starting position, and the nose of the fuselage as my zero moment reference, I weighed, measured and calculated* the following:
3690996235?profile=original
I was surpised that this arrangement seems to put the battery way out in front - much further forward than I anticipated, which will give me some good headroom to add other, lighter things further forward.  I can also double the battery capacity moving the pack CoG back to 345mm, which might be a handy thing!
So, my initial spec will be as follows:
Motor:    NTM Prop Drive 28-36 2200Kv
ESC:    Turnigy AE-45A
Autopilot:   APM1.something
Sensors:   MT3329 GPS
    MPXV7002DP Pitot-static IAS
    MHC5843 remote Magetometer
    LV-EZ0 Sonar Altimeter
Servos:    HTX900 9g
Radio:    Futaba R617FS decased
Battery:   Zippy Compact 4S 25C 2200mAh
More to follow as the build progresses.
*after ripping all the stickers off...
  • How to polish a turd 101:
    Well, never one to leave things well alone, I am somewhere along the homeward stretch on my next Skyfun airframe.
    I have abandoned pretensions of making it break down for packing and glued it all together, laminated it with epoxy and random layers of 18gsm woven glass after cutting big holes in various places for electronic gadgets and ze vires.
    Here is the current status of the basic airframe, including embedded GPS, magnetometer (together at the starboard wing root), telemetry radio (port fin) and, of course, elevon servos (in the wings, stupid!).  All up, this weighs currently 400g - would weigh 260-270g without all the slap.
    3701850483?profile=original
    Projected flying weight with a 2200mAh 4S battery is around the 925g mark - a hundred grams or so more than last time, but with telemetry, which I'm looking forward to using.
    Oh, I should add, it's not just the airframe that's put on the pounds.  The GPS/magnetometer is much heavier and the servos are metal geared thingies.  The proposed ESC is lardy but APM2.5 is at least lighter than APM1.something and I have eliminated or minimized a lot of ze vires, compared to before.  I am also adding a APM power module thingy for learning some more about motor operation in operation.
    All of this extra weight is to ensure this really is heavier-than-air flight. (of course!)
    • This reply was deleted.
      • Daniel - at the end of the first post here is a .zip file filled with various .hex files to suit
        I used this database to figure out which one is suited to which ESC
        I used kkflashtool as well, but I remember it being a bit unfriendly.
  • 100KM
    "Fun" project ;)  Looking forward to progress on Mk2.
  • Skyfun UAV build 2.0 is in full swing now with the weekend's work producing a concept for removable wings.  This is to improve the transportability and shipping of a fully-built airframe.  The main wing spar (5mm carbon tube) slots into a central spar carrier (6mm tube) that passes through the width of the fuselage
    The wing incidence is held with forward mini-spars in the same sizes and manner, excepting that they don't pass through the entire width of the fuselage.  I intend to make the servo plugs connect directly with the plugging in of the wings by bonding the connectors into the right position.  The holding-the-wings-on-tight mechanism is still to be developed.  I expect it will be tape at the wing-fuselage join for aerodynamics purposes as much as keeping the thing together.
    3701721950?profile=original
    3701722303?profile=originalThe vertical stabilizers will be fixed, being bonded directly to the fuselage.
    • Andrew,
      I use a 6mm main spar on a 600mm wingspan 600g plane that flies much slower than this and have had spar failures and flies with noticable flexing. I'm concerned that your 5mm spars will not be strong enough given the speeds that this flies at. I am also building another one of these for the Ardupilot.
      • Hi Jerry,
        I'm still experimenting with the design of how this will go together, so some changes are likely.  Having said that, my original Skyfun ran a 5mm split spar with no problems.  On reflection, I don't think it's actually that effective in bending since the EPS foam wing is quite stiff already.  I plan on experimenting with laminating the entire airframe with glass/epoxy too to improve general handling robustness.  It's worth about 70g in extra weight which I may be able to recover by hollowing out some of the foam in the fuse and possibly wings.
  • OK, so Skyfun Mk2 is in gestation and I've got a bunch of new stuff planned, including telemetry and REVERSE THRUST!
    Here is my new Turnigy ESC with reversible (SimonK) firmware loaded up and functioning.  I am a happy boy right now, having conquered the mysteries of AVR flashing - don't ask me too many questions about it though!
  • I regret to inform the world that my slightly less than beautiful Skyfun met with an untimely fate this morning at the hands of a reckless and incompetent pilot who shall remain nameless for fear of mortal embarrassment. RIP
      • Yes, it was a pretty high-energy crash.  I'm finding missing connectors and capacitors here and there on the boards.  Designing electronics to survive crash damage is a bit of an art, I'd say...
  • So, now it is pretty much complete and physically ready for test-flying.  The thing weighs in, flight-ready, at 826g, which is 67g heavier than I predicted initially, however it does have some thumping great carbon fibre spars that I didn't originally plan on, as well as too much micro-balloon filler and paint...!
    3692794751?profile=originalThe canopy attachment is slightly modified with a front CF "spike", but the standard rear clips remain.  Hopefully this will be enough to avoid losing it in flight.
    3692794789?profile=original
    The layout of the electronics has taken a little bit of fiddling about.  I wanted to make sure that the APM1.4 was located on the CoG.  This is "glued" into the airframe with silicone, as is the ESC.
    3692794816?profile=originalIt's getting a bit crowded down the back and I have had a couple of whoops's with mis-connecting the servo and power leads to the APM, so I have paid some attention to avoiding this by re-connectoring the reciever-to-APM wiring.  The APM board has a few too many repairs at this point, but is still functioning well.  Fingers' crossed.
    3692794910?profile=originalDown the back you can see the pitot sensor which is connected to the spar tubes via silicone tubes.  The spar tubes communicate with the wing LE-mounted old-style 3DR pitot and static ports.
    As mentioned in an earlier update, the GPS and Magnetometer are buried into the wing roots and connected via the leads to the front of the APM1.
    There is also a hole for a sonar altimeter sensor which I might connect up at some point when things are settling down nicely during the flight test program.
    As well as a load of micro-balloon filler used in an attempt to cover up various EPS dings as well as to smooth the wing root gaps, I also reinforced the motor mount with some epoxy-glass and an aluminium spreader plate.  There's a layer of glass roving on the belly from the nose back too, to give it some skid abrasion resistance.
    The foam airframe is painted in Faskolor polycarbonate-suitable acrylic paints and top-coated with Testors clear lacquer - I think this is where some of the excess grams come from.  I chose a high-vis scheme to help with orientation, but also inspired by the Empire Test Pilot School colour schemes.  The underside is dark blue, which you can just see in some of the pictures.
    So, pretty much ready to fly, save for configuring the APM code/parameters.  Flight report to come!
