Small problem with kmz-file in MP 1.2.6
Hi Michael,
when I download the log-files from 'Terminal' in APM 1.4 I get kmz-files where everything seems to be o.k. with one exception, the 'Alt (abs)' of the 'Home location' is added to the terrain (I think this should be zero or 'Default Alt').
For example setting 'Home' on a plateau with 1000m gives a 'Home location' with 'Alt (abs)' 1000m and setting waypoints with 'Default Alt' 80m shows up as path starting 1000m above 'Home' (2000m) and falling to 80m (1080m) at the waypoints. Changing 'Alt (abs)' to 0 the path starts at 0 (1000m) and rises to 80m (1080m) at the waypoints.
Thank you for your work !
    is this for AP or AC as they are diffrent. Im thinking that the planner may have process asuming it was the other one. Please connect to the ap.
    and then goto the redokml option and see if that fixes it.
