Small UAV with Near InfraRed Camera and GPS (Autopilot)
Hello
I like to use a small uav that is equipped with a near infrared camera to take images of various crops showing stressed vs non stressed vegetation (Infrared is good for this purpose). The camera I found is only 7 onces (about 200 g) and it calls for GPS intput to be a true +/-RS232. Additionally, I would like my UAV to be independent in term of missions so that a minimum work is required in the field...Ideally, I would like it to fly itself; so that I can make a file (GPX or shapefile) that shows the exact location of the field/ground where the picture will need to be taken. My last concern is about the stability of the drone/uav and whether images taken with this uav would be clear enough to distinguish between stressed and non stressed crops. Field size I am looking to use it for is 100 acres. By writing my thoughts here, I am hoping that someone in this forum has done something similar and I would very much appreciate the advise...Otherwise, do you guys think I can custom make such a UAV... or does it require advanced skills...
Thanks,
Essam
  • Try Multispek http://multispek.myshopify.com/
    Cheaper, VIS-NIR images at once from a single Gopro like camera. Dustproof, custom optics. For the money best buy.
    I have modified Canon SX260 by maxmax.com and the quality of their service is shit. The resulting images are always blurred, not worth a penny.
  • I have been reading about the steps involved in building an drone/uav. For my purpose of taking infrared photos high in the sky to see stressed vegetation, I think a number of factors are going to be important. I need the drone to be stable when taking photos so for this reason it needs to be not too light (weight wise), and will need a on-board stabilization system to help. Carbon frames seem to be the most stable from my reading (shock buffering). I am planing to use a small digital camera so it should weigh less that 10 oz. If we assume a 4-5 pounds system is going to be stable at 400ft altitude then I need to come up with the proper frame size, motors, speed controllers, flight controller (it seems that AMP 2.6 has more online help material than the new pixhawk; not sure about naza for autopilot and multi waypoints). The last thing is the batteries and I need to be up there for 20 minutes to fly a 120 acres and get multiple shots before landing. I appreciate everyone's inputs. By the way, I think a quadcopter is going to be more reliable and stable than a hexa or octa. Thanks
  • Hi Essam.
    I'm looking for a camera exactly the same as the one you discribed.
    Would you mind telling me the make & model of it?
    Many thx.
    Ricardo.
