Hello i have a small problem with my quad When i put on my tx one clic up my quad go up, one clic down. It. Go down. How can adjust ? Can i make expo on my tx or are some params to be setup on apm ? Thanks a lot for your help. Jl
You definitely want to get rid of that ratcheting throttle. Some transmitters are designed so the ratchet can be removed and tension can be adjusted as desired. Even if not designed that way it's sometimes not difficult to modify the ratchet mechanism, for example in some it merely involves turning a leaf spring over and lubricating it a bit. Have a look before you toss your Tx.
Tanks lot for jour help
