Smoke come out from the chip
I was having problem on my quadrotor project.
Before I had connected the receiver, when I connected the battery with my 4 esc, i can observe that the motor was moving little bit...
After I have connect my receiver, when I use the configurator for calibrate the transmitter, I have found that here are abnormal behaviour. (I am not sure whether it is norma0)-- When I adjust the throttle on  the transmotter, I can see that there are the change in thr roll bar on the configurator...
When I do my calibration with the configurator, then I re-connected my esc, my motor did not spin. when i try to calibrate with my esc, it also fails to do this.. (my esc is new one).. i can feel my esc is quite hot but teh motor do not have any response... I have checked the connection btw the motor and esc too.... When i disconnect the battery and connect it again, i can see smoke come out from the board.. (i'm not sure whether is IMU or ardumega), then i immedaitely disconnect my battery.... after i reconnect back, the smoke did not come out but i still cannot arm the motor....
