If you have other failed Pixhawks, I strongly suggest you review your wiring and connections before proceeding to ensure it is not something you might be doing to damage them.
Look on the SD card for BOOT.LOG file and see if it contains further information. I hope it's something easy to fix.
Not? I am having the same problem....
Hi Justice, i have the same problem, you solved it?
It sounds like "Start up Failed".
See http://copter.ardupilot.com/wiki/common-apm-board-leds/
check http://ardupilot.com/forum/viewtopic.php?f=21&t=5744 and http://ardupilot.com/forum/viewtopic.php?f=21&t=9349 for other examples of this problem.
Good luck!
