sonar help
Greetings,
My sonar is giving me a value of 500cm at 6 inches off the ground... How can I correct this. Thank you
  • Please provide more info on your setup, Jeff.
    What sonar sensor?
    Did you run the CLI sonar test in controlled environment (bench test)? Results?
    Maybe also a closeup photo on the installation...
    Does it respond to height variations when flying (check the log, Sonar)?
