Speed Control beeping alot then goes quiet?
I looked in the manual about the beep codes.  However this one was not listed.  Can you guys take look at the video and tell me what you think?  There is definitely a problem with that motor while running (during tethered and hand testing it seems to be off).
https://www.youtube.com/watch?v=FbimIUIJH2c
Thanks for the input guys!
Riley
    Have a look at your ESC documentation. The beep codes are always spelled out (and different) for each ESC.
    A rapid series of three to six beeps is often used to announce the detected number of cells / voltage, might you be using a 4S battery? If you cannot locate the beep code meanings, I'll find your ESC (you mentioned them on another thread, right?) and locate the info. Cheers.
