Hi
I am experiencing strange problems. When testing stabilize on grund it works as expected. In air, APM will send the aircraft into an inverted spin within 1-4 seconds ins stabilize mode. This is with APM 1 and 2.5 (different recent firmware versons). The APM 1 has been in a Raptor (2m) flying many successful missions.The new airframe is a maja from bormatec.
We have tried the Maja param file from the APM wiki, we have also tried stock settings with the same results. At the moment, I don't have an Idea where to search for the problem. Any thoughts?
Best wishes
-S
I used to fly a Maja. Have some successfull flights, but I dont like the airframe, everithing is too flexible.
The speed is critical, when the airplane stall allways make a violent spin and if you are landing then you have a crash. allways land the maja with enough speed.
The standard parameters does´t work for me. I have to use some unusual parameter to make this plane to flight straight lines.
Now I have much more experience with arduplane and probably start tunning different from my aproach with the maja. but now I have two maja dreaming in my workshop waiting for someone who want to fight with him.
Are you using standard wing or the large ones ? wich is the weight of your maja full ?
You've probably got a channel reversed. Are you absolutely sure all the control surfaces move in the right direction when you test stabilize on the ground?
