Stairs flight in RTL
Hi guys.
My "octa" behaves strange in RTL mode. It flies a little bit in home direction with ascent, then stops, reduces altitude up to initial and again flies in home direction with ascent. It's a "stairs" flight (please, have a look at  flight scheme attached  from  Google Earth).
Duly it was rather windy ( approximately 5-7 m/s) and the copter came back home against a wind. Thus the small quadrocopter (450 mm, 11" props) in the same conditions flied perfectly.
Basic data: octa, diameter on an axis of motors of 120 cm, Pixhack, motors 5008-340kv, props 17", AC 3.2.1
Please let me know how to change PIDs/gains that the copter can fly normally in RTL mode.
Thanks in advance,
2015-06-09 16-54-14.zip
  • Is terrain-following working in the copter code now?  I know it is in the plane code and would explain that sort of behavior.
    Do you have terrain-following enabled?
    • Thanks Scott. You right - this is TERRAIN FOLLOWING issue, thanks
    • I'm not sure is it. But in my config I have
      TERRAIN_ENABLE,1
      TERRAIN_SPACING,100
      and not found TERRAIN_FOLLOW, so I think it can be enabled only in 3.3
  • strangely - Desired Alt is same as Real Alt and both with "stairs" (see pic), so why firmware want to do this stairs?
    https://storage.ning.com/topology/rest/1.0/file/get/3702024606?profile=original
