Strange acceleration reading
Hello,
I downloaded the flight logs from my Pixhawk through the Mission Planner Software and saw something strange.
While the X and Y Acceleration Graphs where centered around 0, the Z Acceleration was centered around -10.
Is this normal?
What can be the cause?
  • Yep. Gravity.
    • Thanks for your reply!
      As you can see, the Pixhawk enters into FAILSAFE_GCS-1 and later FAILSAFE_GCS-0.
      What is the reason?
      What does each failsafe mode mean?
      • Ground Control Station Failsafe.
        http://copter.ardupilot.com/wiki/gps-and-gcs-failsafes/
        • Thanks for the information.
          But I'm still having trouble understanding the graph.
          Please walk me through it...
          Around time 25 the following error kicks in:
          Err: FAILSAFE_GCS-1
          It disappears around time 60.
          Then around time 100 the following error kicks in:
          Err: FAILSAFE_GCS-0
          It disappears around time 135.
          Then around time 150: FAILSAFE_GCS-1 reappears.
          Can you explain exactly what's happening?
          • I can't say what the difference between FAILSAFE_GCS-0 and FAILSAFE_GCS-1, but in either case, the communications between your ground control station and the machine has been lost. Maybe someone else knows what the difference is.
            Since telemetry is non-critical (usually), you can turn it off in Mission Planner. Set FS_GCS_ENABLE to 0.
            • Thanks for your help.
              This is really frustrating. I can't find any information about the
              FAILSAFE_GCS-0, FAILSAFE_GCS-1 errors.
