Strange CTUN Roll behaviour - SW or HW Issue?
I have noticed a strange CTUN Roll behaviour in my Pixhawk-Skywalker.
The plane laid on a table and I saw the HUD moving in my goggles.
The log shows that this is not caused by the IMU.
Since I´m a little bitafraid to fly this plane until this "Problem" has been solved, I would be very glad for any help.
3691297840?profile=original
Bye,
Sven
  • This happened to me, it wasn't as dramatic and I was moving the plane too, but it was scary due to the fact that I was about to launch the plane.
    I do have ARMING_REQUIRE=1 but it does not require GPS check, in tis case GPS had 3d fix.
    What would have happened if I launch the plane while FC is experiencing this instability?
    Thank you!
    Esteban
    3702248350?profile=original
    This is a known problems with EKF2 when you start it with ARMING_REQUIRE=0 and without good GPS and mag data. Paul is working on a fix. I can give you a firmware to test if you would like to help with the testing.
    Meanwhile, always set ARMING_REQUIRE=1 and you will find it is more reliable.
    • Hi Tridge,
      thanks for your reply! When I understand you correct, this issue is "only" a bad initialisation of the EKF?
      I would like to help with testing, do you need my email?
      Bye,
      Sven
  • Here is the corresponding log file:
    https://www.dropbox.com/sh/58xjr9xavlsgy1p/AAC-KNwuldFeMgh_EvbIcL7Ra?dl=02
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
