Strange gyro/accel results after hard crash
Hallo,
after hard crash of my airframe the IMU lost some parts (one slider switch, 4 DIP switches and the relay circuit, see the attached picture).
3690881420?profile=originalInstead slider switch i soldered temporary one (the ugly big one ;-( )
I tried to connect APM via USB and it works ;o)
Main problem but is  when i tried to run tests, the gyro/accel test gives me strange outputs:
3690881487?profile=originalIMU reacts on movement but the numbers from sensors seems to be very small to me. I guess before the accident the numbers were much more bigger.
Has anybody idea if the sensors could be damaged (after huge G-forces applied) ?
I would like to test it now in tricopter but i'm afraid if it won't fail because of the gyro/accel sensors.
  • Can somebody send me such output from gyro/accel test that i can compare the numbers, that looks to me on my APM really small. Best would be the gyro/accel test from APM 2.20.
    That looks pretty busted. Unless you know how to replace SMD chips, I'm afraid you'll need a new board.
