Note to self: stop taking phone calls while trying to build my UAV.I just stripped the blue wire off my motor (a motor which has never even been turned on) as I was trying to remove a poorly soldered connector on the end.
I was able to take the motor apart by removing the sticker, and take the permanent magnet out.
I think I could fix this if I could just get in to solder the wire back on and see where I stripped it from, however, I see no way to remove the inner sheath which contains the wire coils.Is it glued to the metal frame?Also, was about to order a replacement, but it is on Backorder.http://www.hobbypeople.net/gallery/240031.aspI called HobbyPeople - they say they don't have an estimated date.I called Multiplex - they said they're discontinuing this in favor of Hitec motors.What would be a comparable engine to use with the Thunderbird 36 speed controller and 2100mAh 2.1 A , 11.4v 3 Cell LiPo I have?Thanks
