switch to AUTO mode after arming
run into a problem: unable to switch to AUTO mode after arming the motors.
for example, first set to "Stabilize", then arm the motors, now UNABLE to switch to auto mode.
Am I doing something wrong? am I missing anything?   ( mine is apm3.3, have tried using mission planner, mavproxy, rc transmitter )
thanks in advance,
ming
  • Glad you have it sorted. My next suggestion was to check the connections but you got it fixed so all is good and I'm glad it was an easy fix! :)
  • Problem has been resolved.
    stab&althold gps lock, auto,loiter,rtl no lock, this led me think I might need to look at the connection between them.
    So I looked carefully through the cable connections between pixhawk and 3dr gps, and noticed there are two of them ( two connections) were loosened, ( one was pretty bad ),  so I replaced it with a new cable. now it is working. after I arm it, I can switch to auto or loiter or rtl mode now. before I could not.
    Thanks for reminding me the GPS portion ( 6 sats and <2.5 hdop ) which led me to look at the GPS. I was clueless.
    In deed, it was GPS caused my issue.
    Craig, thanks again for your help.
  • I noticed one problem:
    only stabilize and althold modes have gps lock ( green light )
    once I switch mode, immediately "gps not lock" blue light starts blinking.
    read through:
    https://3dr.com/support/articles/210083423/advanced_failsafe_config...
    loiter, auto, rtl require gps lock.
    I am scratching my head not knowing why .... Shed some light please...
    thank you,
  • log files would help [not tlogs but the .bin on the hardware]
  • yeah, I just re-tested and double checked sats and hdop which are 6 and 1.25
    I was looking at "Gps HOP" under "Quick" from mission planner, as long as in my back yard, it is < 1.62.
    define a plan, write wps. set to stabilize, arm,
    then just can't change to AUTO mode.  ( auto mode can't arm the motors, of course )
    So what am I missing still?
    thanks,
  • Thanks for letting me know "6 sats" and "hdop<2.5", I didn't know these, and I will look into them.
    I am using mission planner 1.3.38, so I was doing:
    1. define a plan
    2. write WPs ( upload the plan )
    3. set mode to stabilize
    4. arm the motors
    5.switch to auto mode --- this step stops me. I tried it from mission planner, mavproxy ... just nothing happens. MP didn't show any error mesg.
    But I'll look into sats and hdop.
    thanks for your help.
  • are you waiting until your GPS shows at least 6 sats and a hdop of less than 2.5?
    Also are you connecting to the ground station [mission planner] as it will tell you why normally.
